Results 1 to 13 of 32
    I notice hunter assembly line carries thermostats http://www.hunter-thermostats.com/pr...ostats-all.htm are there any good?
    burlington county n.j.
    no
    Hunter thermostats are good. Good for service department business!!!!!!!!
    Jul 2002
    Zelienople, Pa
    garbage...
    Junk
    Oct 2002
    Why are they junk? May I ask?
    Fort Worth, TX
    Get a Honeywell VisionPro 8000 series and be done with it.
    Even the Honeywell "Vision" (a stripped VisionPro) sold at Lowes is a better stat than a Hunter any day.
    Building Physics Rule #2:
    Building Physics Rule #3:
    Apr 2002
    NW Indiana
    Talking
    Let's see how many times???
    What did you do to get the heat back on?
    Replaced the stat.
    Hey I just put that on a couple yrs ago.
    RIGHT
    Are you telling me thats why we were cold last night
    RIGHT
    I paid bla bla for that thing and now I have to buy another thermostat already?
    RIGHT
    "The Bitterness of poor quality remains long after the sweetness of low price is forgotten"
    SE Michigan
    Every household should have a hunter thermostat. I recomend them. Its good job security.
    “Now the freaks are on television, the freaks are in the movies. And it’s no longer the sideshow, it’s the whole show. The colorful circus and the clowns and the elephants, for all intents and purposes, are gone, and we’re dealing only with the freaks.” - Jonathan Winters
    Oct 2002
    Still no answer as to why they are junk.
    Been using one for 7 years now. With no problems.
    What can one expect to go wrong with one?
    Dec 2001
    Woodstock Ga
    my experience with them is that if there is a heat problem and the stat is a hunter, that is the problem. power stealing properties possibly? never had a problem in a/c though
    as to going wrong, the intermittantly call for heat
    ONOFFONOFFONOFFONOFFONOFF
    In the land of the blind the one eyed man is King! semper fi
    SE Michigan
    I find that they use cheaper electronics and therefor do not last as long. Plus they suck.
    Apr 2002
    NW Indiana
    Not every single one is doomed for failure but in the big picture seem to be problematic as far as stats go.
