Results 1 to 11 of 11
Thread: Yaskawa VFDs
    Austin, Texas
    Does anyone know if Yaskawa model E7U VFDs can tolerate an electrical disconnect between the VFD and the motor? Some drives will smoke the drive (catastrophic failure) if the disconnect is shut off while the drive is operating the motor. I've looked through the manual and don't find any indication that a disconnect should NOT be installed between the drive and the motor or that it is OK.
    Call Yaskawa tech.support 1-800-972-5292
    Have model and Serial # of drive Ready
    There the one's that can say yes or no.
    Austin, Texas
    I got the following email response back from Yaskawa.
    "The E7 drive, as well as all other Yaskawa drives, will tolerate a disconnection between the drive and the motor while in operation. However, at no time do you want to close a contact between the drive and the motor while the drive is running."
    Hmmm, I thought it was the circuit being opened that smoked the VFD. From this answer it looks like these VFDs will tolerate the circuit being opened, but not remade. It sounds like the disconnect would have to have a sign something like "Turn off VFD in room 105 prior to switching disconnect back to ON".
    Would that make sense to you if you were on a roof working on a fan with no VFD in sight?
    I would get rid of Disconnect and turn off and on from vfd
    Because somebody is not going to read the sign and blowup the vfd.
    Make sure you lock and tag for safety
    up in the hizzy
    Why the vfd would blow the motor? as far as I know vfd work by converting the ac signal into dc, then the capacitor bank stores the dc power and the inverter converts it into a variable ac output.
    Sep 2000
    Miami, Fla. USA
    A really great installation will have a micro switch in the service disconnect. If you pull the handle the VFD will shut down on external interlock before the knives break. A normal restart will then occur upon closure.
    But then again how many great installs are there?
    By the way, Yaskawa was right on.
    Sep 2000
    Miami, Fla. USA
    Sorry man, you cannot get rid of the disconnect. Think safety over equipment.
    Austin, Texas
    That would be the best solution. Second best would be to run power from the breaker to the disconnect, then back to the VFD. That way when the disconnect was opened it killed the VFD. But this is already installed so no one wants to change anything. Engineer thought he could specify that the VFD had to tolerate a disconnect anywhere. Unfortunately, there don't seem to be any of those VFDs available. If only engineers were really as good as they thought they were...
    Talking
    Valdelocc
    The VFD Blows up not the motor.
    Major damage to the Rectifier circuit inside VFD, lots of fire and smoke!
    Things never work when you let the smoke out.
    up in the hizzy
    Mi scusi ,Mi scusi
    Dec 2003
    Install a disconnect with a "late make, early break" aux. contact. Then just intterupt the "run forward" input on the VFD through that aux. contact.
