Results 1 to 7 of 7
    Jan 2011
    trouble shooting request
    I have an old 15-20 yr old consolidated (hda060?) furnace that works during the day and shuts off at night. Likely needs replacement. I replaced programmable thermostat but no difference. If replacement is necessary, what is recommended. Would like to repair as budget tight this year.
    Jun 2008
    Cincinnati, Ohio
    The equipment is outsmarting you, methinks.
    Check the programming on the thermostat to see if you have set the temperature back at night.
    Anything more than this, I'd call a professional HVAC tech to diagnose the problem.
    Nov 2010
    Kansas
    Welcome to the site mskye,
    Glad to have you join us. There are several things that can cause it to lock out, so I recommend having an experienced tech out to look at it and diagnose what the problem is...especially since you would rather repair it instead of replace it.
    If you replace, I recommend a 95% t o96% two stage variable speed furnace.
    Good luck,
    The statement below is my signature and just my overall feeling towards our industry and does not necessarily pertain to you nor this thread.
    There really isn't a legitimate excuse for not doing the job correctly!
    Dec 2010
    New Orleans
    Make sure this unit was not a recall unit that had heat exchanger problems.
    Oct 2009
    Atlanta,Ga.
    I agree with the other techs,get a good service tech to find out the problem and repair the furnace.what if you get a new furnace and the problem was justthe thermostat? Find out the problem,and go from there.
    lexington ky
    If repairs go above a quarter the cost of replacement, I'd replace due to age
    welcome!!!!!!
    true knowledge exists in knowing that you know nothing.
