Thread: York Diamond 80 problem
01-11-2011, 01:25 AM #1
New Guest
- Jan 2011
- 2
Here's my situation, I have my thermostat set to 70, the fan is on the auto position. The furnace wouldn't kick on to heat the house. I opened both panels to see what was wrong. I pressed the switch to activate the furnace, it kicks on, the burner ignites, lights up for a few seconds and shuts off. I thought maybe the fan was stuck so I switched the fan to the on position on the thermostat. The fan kicked on. So I know it's not the fan. I then cleaned my filters and reinstalled them. I turned the furance off, to reset it, and turned it back on. I replaced the panel that ingages the pressure switch, a minute later the furnace kicked on, burner ignites and stays lit, basically working properly. This went on for a few cycles, and then the furnace wouldn't kick back on again. I went through the same cycle. Is this a control panel going bad or something else?
01-11-2011, 01:26 AM #2
New Guest
- Jan 2011
- 2
by the way this is a York Diamond 80 furnace
01-11-2011, 01:34 AM #3
Call a service company and have them perform a tune-up on your furnace. It's due for some cleaning.
