Results 1 to 8 of 8
    Can anyone brainstorm and think of how changing a transformer for the t-stat in the air handler, changing a thermostat on the wall or changing a board in a compressor (all three have been done to my system) change the cooling in the farthest end of my house. Lennox system 3.5 ton heat pump, installed 2003, worked great. Had this work done Spring 2004 cuz transformer kept blowing in handler, and cooled differently afterward. (Ducts are good, no leaks per FPL.)
    Chipper
    North St Paul MN
    What was the reason given for the transformer blowing? (Usually, they don't just burn out without another problem)
    Is this system zoned?
    I'd rather have a bottle in front of me, than a frontal lobotomy.
    No system is not zoned. The circuit board in the compressor was the cause of the transformer to trip.
    Chip
    North St Paul MN
    Just read your other post. Please do not double post about the same problem. Your received alot of good information from the other post. Good luck.
    Post Information needed...
    What kind of system is this, model,serial would be helpful.
    AllTemp Heating & Cooling
    Sorry Markco, didn't know you couldn't repost. This was a little different question, more simple I thought.
    Lennox 3.5 ton H.P. Model CB30m-46-1P and HP26-042-12P
    Chip
    Hmm What he said...
    See other thread..................
    leland nc
    go back to your first post and follow what is said there
