Results 1 to 8 of 8
    Looking for a chart, or the mathamatic formula, to find the RH when canging temp. Example: the air is 50 deg and RH of 60%, what is the RH of the same air if warmed to 70 deg ?
    Did some on line looking, but no luck.
    Thanks,
    Nick
    South Dakota
    You are looking for a psychrometric chart. Perform a search for "psychrometric chart". Or perhaps someone here has one in pdf they can post for you.
    The answer to your example is 30.
    For a pyschrometric chart you can go to the following link:
    http://ohioline.osu.edu/aex-fact/pdf/120_2.pdf
    Printed out a Psychromeric chart.
    In My example: I find the original temp along the bottom, go up till it intersects the correct RH, then go horizontal till I intersect the "new" temp and this "point" shows the new RH ??
    so if the air temp is 40 deg, 30% RH, and I warm that air to 70 deg, the RH would be 10% RH ?
    Thanks,
    Nick
    looks like it is,nicholasa
    Nick
    Ask somemore questions if you want.
    I dont really know if I can be much help,but...
    Feb 2005
    Here is a link to "McQuay" it is their public website,
    When you get there, on the left you will see design solutions. go there and choose desing tools,, one of the tools is a neat little Psych. program,,,,it is free but will run out in time, and will need to be redownloaded about every 6 months I think.
    This may help http://www.mcquay.com
    I do not work for McQuay, it is a public site.
    [Edited by fat eddy on 03-23-2005 at 04:15 PM]
    Huntsville,AL
    if you can program in BASIC, go to Controls forum -- this thread can be used to get the equations --
