Results 1 to 4 of 4
03-20-2005, 03:37 PM #1
- Mar 2005
- 2
I have a Duo-Therm propane furnace that i use to heat my garage/workshop with and would like to convert it to natural gas. Now I know i have to have the orfice changed but I need to find the manufacturer to find out if i can even get the conversion kit, as it is an older furnace. So can anyone help me with who is the manufacturer and how can I contact them. Have searched the web to no avail.
03-20-2005, 03:42 PM #2
- Jan 2005
- 99
I would suggest hiring a profess. to perform this conversion swapping out parts is not the end of it, a combustion analysis should be perfomed to meet proper combustion requirements.
03-20-2005, 04:27 PM #3
- Jun 2003
- Battle Creek MI Occupation: Simi-retired 57 year old, in home and shop appliance tecnician, (since 1967).
- 62
If it has ran a long time on Lp, it may get very complicated, you need to change and check a lot more than just the orifices. Also know how to spot things like lazy diaphrams, and have the proper equipment to set pressures, flame placements and on and on. Get a good contractor, or at least, someone who has done a lot of conversions and knows what mistakes to avoid.
03-20-2005, 10:01 PM #4
Member
- Jan 2005
- Gilroy, Calif
- 188
If it has a LP gas control valve the internal regulator has to have a conversion kit also or you need to install a appliance regulator outside of the valve. Better contact a professional. You can get in alot of trouble.
