Results 1 to 13 of 13
    peakslayer Guest
    Carrier Gas pack Model number
    Hi warm people..
    I have a 20 year old carrier combo gas pack on my roof but cant seem to find the model number due to all the info being sun faded here in HOT Tucson. I do have a couple part numbers of two control boards and pictures to boot.
    Anyone out there have knowledge of old carrier unit if I give you a part number off a board and some pictures, CARRIER WON'T TALK TO ME AND WHEN I HAD A DEALER CALL, THE GAVE THEN 200 POSSIBLE PART NUMBERS.
    Or can someone tell me where to find a model or serial number on this unit
    Thanks a MILLION in advance
    Cold person for a week in Tucson...
    Jun 2008
    Cincinnati, Ohio
    Behind a panel on the unit, there's another silver panel covering the electrical control box. Carrier puts another nameplate there. Hopefully that one isn't oxidized or faded away.
    peakslayer Guest
    eletrical control box?
    THANK YOU!!!!!!!!!!!!!!!!!!!
    When you speak of the electrical control box are you speaking of the compartment with the control boards? See picture attached
    Steven
    Dec 2010
    New Orleans
    Why do you ne3ed the model #. Is it not working a technician could probably fix it in a short time.
    Jun 2008
    Cincinnati, Ohio
    Quote Originally Posted by peakslayer View Post
    Steven
    Yes. Was there not another silver panel in front of the control box?
    peakslayer Guest
    No,,,what you see in the pic is what I have, able to read the serial number off the tag. Any way to convert it 3190007255
    Jun 2008
    Cincinnati, Ohio
    You might have to call a tech in to take a look at it. As the dealer said, there's hundreds of possibilities.
    Nov 2009
    a matter of effort
    lack of a model number does not mean your out of luck, as someone who used to work a parts counter for a carrier distributor i know a thing or two...first of all part numbers can help by narrowing down potential models as carrier distributors have a program to cross refrence those numbers to the various units they were used on (providing the unit isn't too old)...secondly, if you know the age of a unit the results can be further narrowed by what models were manufactured during that period. in the end it is still going to be a guess but narrowing down to a dozen or so candidates is possible. if you post a part number for the control board and the compressor (if readable) and guestimate the age i'll see if i can call a few contacts to narrow down your possibilities a bit
    Nov 2009
    just hit me the serial number you provided 3190007255 is probably 3190 G 07255 which would be a 1990 model unit. does that sound right?
    peakslayer Guest
    Carrier model number
    yes I believe it is a 1990 model
    edmonds wa
    i have a contract with 30 of thes units. mine are 48nlt 036501be. 1989 year built.230 volt 3 phase 3 gas burners natural gas .hope this helps.try cleaning up the area around the wiring diagram, there might be another mod aand ser # there.
    peakslayer Guest
    Hi
    Thanks for your input.
    I did clean up around the wiring diagram and have been over that unit with a magnifier. Still no luck
    BTW,,this has 4 gas burners
    thanks again!!!
    Steven
    Nov 2009
    a 48n_t model does fit the appearance and time of manufacture from what i see. that information along with knowing how many burners has norrowed down the information to which i have access to the following possibilities...
    48nht030
    48nmt036
    48nht036
    48nmt042
    48nht042
    48nlt048
    48nlt060
    these models do have the stacked circuit boards as show in your picture so if your unit is in fact a 48n model theres a good chance one of the above will apply
    030 = 2.5 ton / 036 = 3 ton / 042 = 3.5 ton / 048 = 4 ton / 060 = 5 ton cooling
    good luck
