Page 1 of 4 1234 LastLast
Results 1 to 13 of 52
    Jan 2011
    Confused goodman 5 ton split sys new..equal rise on pressures
    New system provided by homeowner. Upon initial startup pressures equally rose. By the time it got to 250 on liquid and suction I shut it down... so it basically acts like there is a blockage. There are two pistons in the system one inside and one outside. The outside piston is supposedly located in the liquid service port. The thing doesn't even look like a service port..any help would be much appreciated!!
    New system provided by homeowner? Oh Lord, here we go.
    Jan 2011
    Eugene Oregon
    Possibly extremely overcharghed.
    There is a no DIY rule on this site.
    We can't offer much help to you unless you prove that you are a professional in the field. We have technical forums to discuss matters like this in.
    That said, I don't think that you are looking at a blockage of any sort.
    Jan 2011
    Hmm
    I am not a diy er.. licensed and refrigerant cert.
    Jan 2011
    Its about 40 ' of lineset...all its got in it now is the charge from the factory..
    Quote Originally Posted by boxedn75 View Post
    Let me ask you why you believe this to be indicative of a blockage?
    Explain.
    Also, did you take readings other than pressures?
    Nov 2005
    Charlotte, N.C.
    I agree I've seen this many times with inexperienced people in the field.
    Those who restrain desire do so because theirs is weak enough to be restrained. (William Blake)
    Quote Originally Posted by trey r View Post
    Heck, I've done it a few times, too.
    I just recognize it a LOT faster than I used to.
    Oct 2010
    Houston, Tx
    Is the compressor staying on or is it shutting off?
    Jan 2011
    I shut the system down before it had a chance to heat the internal overload.. I will admit that i could be considered a tad green..this will be my fourth year in this field.. I did feel the liquid kins and it was heating..I've just never run into this issue..
    Why do you think that this was caused by a blockage.
    I want to try to get my head around your thinking so that I can help to correct it.
    Mount Airy, MD
    Trying to make a quick buck on the side and things have not panned out so good, hmmm....
    Any co-workers not so green that you could have assist?
