Results 1 to 9 of 9
    Nov 2000
    Coastal Georgia
    Two months old and combustion motor went bad. Changed it.
    Combustion motor came back on without a call for heat and will not shut off. Checked the limits. One is manual roll out and another auto at the indoor fan motor. Gas valve opens and shuts from the thermostat. First one of these I have installed... looks like a Carrier. I suspect a micro relay on the board. Any ideas?
    Jacksonville, FL.
    Yeah. Change the board. Sometimes when the combustion motor goes south it also takes out the board.
    BTW, what was wrong with the motor in the first place? Locked up & pulling high amps?
    Nov 2000
    Coastal Georgia
    Open...slight discoloring on the schematic that is close to it. Thanks..
    Jacksonville, FL.
    Anytime.
    I think Carrier bought out ICP which makes Comfortmaker, didn't they?
    Nov 2000
    Coastal Georgia
    Yes and I think this is a Carrier RTU
    Apr 2003
    No, that is not correct.
    UT (United Technologies) who owns the Carrier Corp. bought ICP. They are not the same units.
    Some of the units are made in the same factory, but assembled on completely different lines.
    So, anything that falls under Carrier is similar, and anything that falls under ICP is similar.
    Jan 2003
    You are correct. Everyone thinks Carrier bought ICP and that is NOT correct. UT is the owner.
    Jacksonville, FL.
    Uh, ok.
    If I owned Chevy & then I bought Ford, wouldn't I be considered the owner of both companies? I think so. And if you think UT isn't gonna incorporate some parts into both co.'s you'd be high. Watch. Wait. You'll see.
    Apr 2003
    Does this mean that because 'Red Lobster' and 'The Olive Garden' are owned by the same company, that they serve the same menu? (I think not!)
    Look, I didn't say 'EVERYTHING' is and was different, I simple stated the correct buying party. And that the unit he is working on is NOT a Carrier product!
    Further you asked 'If I owned Chevy & then I bought Ford, wouldn't I be considered the owner of both companies?'
    Yes, you would be the owner of both, but that's not the same as Chevy buying out Ford. This is what was stated before and it was WRONG. Shareholders and other things here makes it all different.
