Results 1 to 7 of 7
    May 2003
    SoCal
    After suffering through two winters with absolutely no heat in our small house, we finally had a gas wall furnace installed last December. Despite enjoying the pleasure of warmth and not having to sleep with skiing attire, we do have a small issue: once the heater is turned down/off it is immediately followed by a "clunk clunk" sound, which eventually will die. Any suggestions what the cause could be?
    SE Michigan
    contraction of the heat exchanger possibly.
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    danger is offline Professional Member - bad email t member
    May 2003
    Having a gas wall heater in my own house, I tend to agree on contracting noise, mine does the same thing when heat cycle ends.
    Jan 2005
    Gilroy, Calif
    My house does the same thing. Piss poor installation. Mine has a heat sheild between the HX and outer cover. Installer did not leave room in mounting frame for expansion. Could be the model too, but have seen others that do not make noise. My model is a Williams, double wall.
    Jun 2000
    WYO
    williams, cozy, they all do that. get used to it.
    never say never
    May 2003
    SoCal
    thanks guys, guess we just have to live with our noisy, "Cozy" furnace .....
    I have the same problems with a Williams, but I am convinced that this did not have the problem the first year that I lived here. There MUST be a solution, I hope.
