Results 1 to 7 of 7
    Mt.Sterling KY.
    Confused Fuel Oil Furnace HELP
    Fuel oil furnace will Prime up and run for about 4.5 hrs. and then it will just use up oil in the filter well and tripp off. Filter is new and nossel and transformer is working fine can't find any air in system or leaks in lines looks as if the tank is almost full with about 38 inches which converts to about 785 gals. what do you all think????????????????
    Mt.Sterling KY.
    Fuel Oil Furnace will operate about 4.5hrs. then pull remaining oil out of filter and loose prime and tripp out reprime and will run about same time new filter new nossell and rods transformer is good and no leeks or air in lines.PLEASE HELP what am I overlookin?
    Merged your 2 threads on the same subject/problem. Please don't make duplicate threads across the forums, thank you.
    You should get your post count up to 15 and apply for pro membership. Once accepted, you'll have access to the pro tech forums.
    We also have a pro oil burner forum, where you would get many answers to this question.
    Jan 2005
    Orange County, New York
    freonfrog723,
    but you need to have pro status to get some help from tech's because there is no DIY. There is a whole oil heating forum in the professional area with tons of information and helpful technicians. There is a number of things that could be causing this. Are you a technician or a homeowner looking for some help.
    Needless to say, please make sure you read the rules!
    hvacsteve82
    Only pro members have PM ability.
    freonfrog723.
    Don't make anymore threads about this.
    I deleted the one you just made in residential.
    Rochester NY
    Single or 2 line? May need to sell em a return. Hear they are much less problemmatic.
