Results 14 to 24 of 24
Thread: Oil heat CO2 is Too Low
03-15-2005, 03:44 PM #14
Either you use a whole lot of hot water water over the summer, or your boiler is at 60% eff.
Does it have a triple aquastat, a single, or duel.
If it has a triple, bypass the reverse action, or at least turn the low down.
03-15-2005, 04:14 PM #15
- Jan 2005
- Massachusetts
- 250
With that burner your lucky it runs at all. A new Carlin would definatly pay for itself in short time
03-15-2005, 05:04 PM #16
- Jan 2003
- North of Boston, MA
- 270
Aquastat & Carlin
I have a single aquastat. How long would it take to recoup the cost of a new (Carlin) burner? Aren't they about $500?
"You miss 100% of the shots you don't take"--Wayne Gretzky
03-15-2005, 06:12 PM #17
- Jan 2005
- Massachusetts
- 250
you can get one with a standard control for less than ***
[Edited by heaterman61 on 03-15-2005 at 07:01 PM]
03-15-2005, 06:25 PM #18
Shouldn't post a price in the resi area.
03-15-2005, 07:02 PM #19
- Jan 2005
- Massachusetts
- 250
Didnt think about it, Thanks for reminding me
03-15-2005, 08:00 PM #20
When you replace an old oil furnace take the burner before it goes to the scrap yard.
03-15-2005, 11:05 PM #21
- Sep 2004
- 654
Re: Old beckett
Save your money and replace the entire boiler instead. A good electric water heater is about 1/3 the cost of a good cast iron boiler, but the boiler will be around alot longer than any electric water heater. An economical steel boiler that's really not all that bad is a dry base Burnham. I've seen plenty of these units in the field and they've lasted quite awhile and tankless coils are soooo easy to change. That boiler is only like twice the cost of a good electric water heater too. Something to think about.Originally posted by hockey
I am seriously leaning toward an electric water heater. Sounds like a payback in 2 years.
03-16-2005, 12:04 PM #22
- Jan 2005
- Massachusetts
- 250
New Yorker which is owned by Burnham makes a great steel boiler.
03-16-2005, 12:06 PM #23
- Jan 2003
- 270
New Burner
I have alot to think about. I've been talked into keeping the Amtrol. My home heatloss calculation is in the vicinity of 35,000 BTU's plus another 40,000 BTU's for the Amtrol indirect water heater. That's 75,000 BTU's. If I can get a 75% efficient burner to stick into my chamber I can use a .70 GPH nozzle and save 25% immediatley. I'm probably spending $1,000 annually now.
03-16-2005, 05:08 PM #24
- Jan 2003
- 270
Draft Meter Malfunctioning
I just compared my Bacharach draft meter to a pocket style draft meter. They disagree by .04!!!!!
