Results 1 to 13 of 15
    I'm troubleshooting a RHEEM packaged heat pump, 13 years old. There is no control voltage coming into the t-stat. The outdoor unit breaker has power. Is the control transformer the likely culprit?
    Grottoes VA
    You will need a little more training, IMHO.
    There could be a lot of differnt things that could be happening.
    If you know how to use a meter to check the line voltage, you should know how to use it for low voltage testing.
    This is a rather basic problem, if your having trouble with it, you need alot more training.
    Hint: not all units have a common at the stat.
    If you suspect that the xrfrmr has failed , go right to the xfrmr and check the primary and secondary voltage,don't leave things in doubt, you will end up going in circles with no clear path to determine what the real problem is.
    Sorry bruce, Site rules prohibit us from giving you step by step instructions on how to fix your unit. Your best bet would be to utilize the services of a pro.
    Toledo, Ohio, United States
    huh? help the guy out he's a pro member afterall.
    daytona florida
    and should know what he is doing
    South Carolina
    eddy breaking the rules again
    Sep 2001
    East Stroudsburg, PA
    Profile says he's a "mechanical engineer".
    Question asked is DIY'er. Basic electrical 101.
    Sounds like another phony "professional member" slipped under the radar....
    Email being dispatched in 3-2-1...
    leland nc
    if you have no 24 volts at the t stat
    then trasformer is probably the reason
    if the transformer is bad there is a reason and changing it will most likely waist the new one two
    something has most likely shorted out and taken the trans. out with it.
    if you are sure of yourself and ask a question of this nature then i would sugest you call one of your coworkers and see if he can help you out on this. heatpumps have a lot of controls and if you are not use to working on them you will go nuts. all i can say in here is 95% of the time a transformer does not just go bad something has burnt it out
    get some help before you go any farther with this
    some units have more then one power sorce comeing into it
    so get some help before you go farther
    Sounds like You've solved his problem. I wonder how you check for 24volts if there is no common. I guess if your leads on your meter are long enough you can get to a water pipe somewhere in the house. But what if the water pipes are pvc. Run a common up to the stat,,,what was I thinkin.
    leland nc
    twilli3967
    probably and if is not solveing anything
    get some help before you go further is what i was saying
    guess i shoud have said maybe or maybe not get so help in stead of telling him why he should get so help
    thanks and i will word things better next time
