Results 1 to 8 of 8
    Apr 2003
    Toronto
    I need to choose a programmable t/stat with 2 stages of heat and at least 1 stage of cooling. It will be used with 2 stage gas furnace and a regular a/c.
    Important features are: reliability, ease of programming, look and price of course. I found quite a few models at this site. http://www.white-rodgers.com/homeown...fo_list_ms.htm
    Which one do you prefer? Could be any manufacture.
    Thanks in advance for the help,
    gm
    gm10
    I would recommend the new Honeywell Vision Pro series, our company likes to promote only thermostats that offer the features you are looking for. The Vision pro I believe offers 3 versions 1) 1heat/1cool,3heat/2cool and 3heat/2cool with humidity control. They have battery back up feature that in most cases does not require a independent "common" terminal (you don't have to run new wires), they also have daylight savings feature that most programable stats do not feature. Best of all is the cool touch screen and easy programming. Our customers love them, we have installed aprx. 50 with no problems to date.
    Check them out here:
    http://customer.honeywell.com/Honeyw...CFB4218DD64%7D
    Thermostats - TH8110U1003
    Thermostats - TH8320U1008
    Thermostats - TH8321U1006
    Seattle Area
    Honeywell, Vision Pro 8000
    Rochester, MN
    Apr 2003
    Toronto
    Smile
    Wow, that was quite a vote of confidence. I was expecting more "diversity".<BG>
    Thanks a lot everybody for the help.
    gm
    gm10
    Jan 2003
    Olathe Kansas
    O.K. White-Rodgers are good too.
    leland nc
    i like the w/r stats they are good and reliable but honeywell is the best
    Any will do as long as it isnt the model sold by HD or L.
