Results 1 to 13 of 13
    Saint petersburg, FL
    Hello,
    I have an issue with my Rheem classic XI, it started blowing hot air and kept freezing up, I had it recharged and within 3 weeks it was blowing hot again, I had a technician come out and he said that my accumulator is leaking. There is a lot of rust on the top of the accumulator where the pipes run into the top and I saw the leak sensor going crazy when he passed it over the area. The rest of my system in great shape. Here is my problem. I have a friend that is certified in HVAC, but he wants me to get the replacement parts. I can only find one size accumulator for this AC, part # 83-22459-07 I found it on a parts supply store online for $129 and at sears for $79.00. Is it one size fits all for accumulators? Thanks!
    You need the exact accumulator. What's the model # of the HP?
    the model number is RPLA-034JAZ
    Ser # 5156 M3995 2607
    Thanks!
    If your friend is HVAC certified he should be able to get the
    part if you give him the money for it. He needs to have a
    recovery unit to remove the refrigerant to replace the accumulator. Why not have the original service tech you called do the work?
    Whoa Maynard - that's not how it works.
    my friend just wants me to learn a little something, as far as calling the original tech, he quoted me $450.00, my friend will do it for $100.oo + 1 case of Busch and parts.
    daytona florida
    i will never understand why someone doesn't let a professional do what they are trained to do. if you have your friend do the job just give him model and ser. you'll be fine
    actually my friend is more than qualified, he primarily works on commercial units for the last 20 years or so, he is just doing this as a favor, and I know he will do a good job, I don't like to work with people I don't know.
    Will
    You and your friend should set there and drink the Busch, and let the tech replace the accumulator. You will also get a warranty with the tech.
    So you gotta get the accumulator, the gas, and the new filter drier.
    And he's only charging you a hundred bucks, and a case of beer.
    How you going to get the gas.
    Seattle
    Talking Acumulator
    Beenthere. Jesus brother.I thought you were a real pro from reading the thousands of other posts you have replyed to.Anybody who has been to even ONE of those two hour with free pizza after hours tech classes knows.
    If you drink a case of that BUSH stuff they call beer.Anybody will have way more than enough gas to charge even the largest residentel heatpump system.And the bush beer comes with it's own accumulator. YOU!!!... :}
    AS for a new filter dryer.......Well I guess a guy better double up on the shorts before he starts the job.
    41GASMAN
    [Edited by 41gasman on 03-13-2005 at 05:29 PM]
    Re: Acumulator
    41GASMAN
    ROFLMAO.
    leland nc
    lmao to
    you need to exact part and it isnt that easy to replace it is a pain inthe ass. we arent to talk monie here but 450 is good price i am a lot more than that. you and your friend should sit on the deck have any kind of beer and let a pro do the jod for you
