Results 1 to 9 of 9
01-05-2011, 09:00 PM #1
- Nov 2010
- kentucky
- 161
Trane Voyager ignition control module
md# YCD150D4LBBB
ICM board #X13650882-01
Anyone have any detailed troubleshooting info. on this control? IO&M doesn't say much about it.
Thanks!!
01-05-2011, 09:19 PM #2
Professional Member*
- Dec 2005
- 1,655
All diagnoses and test are on the frnot of that small panel.
That's it buddy. This POS does not tell you what failed.
It just says "cool fail" or "heat fail" by measuring voltage between terminal 6,7,8.
Even those blooming idiots from trane could not tell what part caused the failure.
They say "cycle the power and hope for the best"
01-05-2011, 11:27 PM #3
- Oct 2009
- Atlanta,Ga.
- 193
Will check Trane voyager manual and let you know if i find anything that helps!!!
01-06-2011, 06:25 AM #4
- Dec 2002
- SouthEast NC ICW & Piedmont Foothills
- 7,217
here you go
01-06-2011, 08:49 PM #5
- Nov 2010
- kentucky
- 161
Thanks for the info!!!
12-28-2012, 02:38 PM #6
- Apr 2003
- Long Island, NY
- 11
I guess the info was removed? Having a hard time finding this paperwork or PDF!
12-28-2012, 04:19 PM #7
- Dec 2002
- 7,217
nothing in that profile indicates you are a service tech,
more than likely, I removed it after giving them enough time to see it
generally will not put tech lit in open forum, never know who's lurking out there
12-28-2012, 09:06 PM #8
good luck ..... worst ignition system in the trade by far.....
12-28-2012, 09:21 PM #9
Moved to tech to tech commercial
