Results 14 to 19 of 19
Thread: cooking
    Oct 2010
    If your condensate traps are leaking ( what looks like a dryer) coming off the compartment supply lines then you could have the steam travel back up the compartment drain line and vent. Normal function of these traps are to drain off any water in the steam supply lines but not allow the steam to vent.
    Des Moines, IA
    Steamer works great in on position. yes on the jmet stream. yes 1.5" black iron though. 3 90's and less than 4' run.
    steam vent through drain when in stanby. Going to have to find a parts break down.
    Oct 2010
    Look at drawing number 105881. Most likely your problem is here.
    http://www.clevelandrange.com/docs/u...GA10_Parts.pdf
    Des Moines, IA
    I believe Ur correct, Think they can be cleaned? they are not cheap, but easy to replace
    If you are talking about the thermostatic trap it's best just to change them out. They can't be taken apart to be cleaned and if you try to soak them in a cleaning solution your labor would be more than the cost of the trap.
    Des Moines, IA
    thank you for the hel[p, traps took care of the problems
