Results 1 to 11 of 11
Thread: YSCACAS2-CKCS
    MEXICO
    YSCACAS2-CKCS
    guys:
    this day found in a machine YSCACAS2 display the following warning: STARTER MALFUNTION DETECTED. that causes this alarm? the machine is stopped.
    thanks
    is it a solid state starter?????????????
    true knowledge exists in knowing that you know nothing.
    Somewhere in the world.
    Quote Originally Posted by supertek65 View Post
    Only comes in SSS.
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    MEXICO
    starter electromechanical
    wee, that answers that!!!!!!!!!!!!!
    Quote Originally Posted by york56 View Post
    Only comes in SSS.
    Everyone I have worked on was only SSS never seen a electro mechanical on a YS nor do I have any literature that even shows it exists sorry about that.
    Looked way back to the A machines found that they came thru with either electro mechanical or optional SSS also found this page appears motor current >15% for 10 sec.with control centernot calling for motor to run. Check motor starter operation , motor current value greater than 15% fla. to reset press compressor stop/reset then switch back on.
    MEXICO
    YORK 56:
    This alarm has been generated by the machine stopped. this machine the use of standby, a machine version A
    Ok so we have a electro mechanical starter and this chiller is for stand by and alarm is generated by a current reading greater than 15% of motor fla for 10 sec. without any command to run from control center micro panel first I would check all ct's in starter and verify that your not reading anything at micro panel without running also check all your wiring and connections for high potential current reading that may give you a false indication back to the micro processor start with that.
    YCAJ
    hello alll good luck in 2011
    MEXICO
    Boys:
    was presented at this alarm and the machine stopped malfuntion detected starter
