Results 1 to 13 of 17
Thread: Honeywell TrueSTEAM Humidifiers
01-03-2011, 06:39 PM #1
- Nov 2010
- Western Mass
- 21
I was wondering if anyone has had experience installing any of these and what there opinions were of them. I do mostly industrial work so I haven't run across one and I'm looking at one for my own house. The furnace is in the attic and so I need something remote mounted as I don't want any water lines up there. The exact one I'm looking at is the HM506DG115.
01-03-2011, 07:50 PM #2
Hello,
Is that one the right size for your home. They are rated by cubic feet.
A remote mount kit is optional (but is limited to a certain distance). A dedicated receptacle is required.
Someone with experience installing these is recommended.Every problem gives us the opportunity to choose from several solutions: stupidity, ignorance, indifference, or brilliance. Which one will you choose?
01-03-2011, 09:46 PM #3
The 506? Boil a pot of water when your at home then. And you'll get more humidity then it will give you. I thought they were discontinuing the 506.
Before installing a humidifier. Seal your duct work, if you haven't already. And improve your homes envelope by sealing it better.
01-03-2011, 10:18 PM #4
01-03-2011, 10:46 PM #5
- Jun 2010
- 156
Not a fan of Honeywell True Steam. I had a retainer pop out...that little fitting that you put the hose into. The fitting itself popped out, not just the hose.
Hi jid1877, good to see someone local.
01-04-2011, 06:48 AM #6
- Nov 2010
- Western Mass
- 21
01-04-2011, 06:55 AM #7
Thats a 2,000 sq ft tight house. And it better be a very very tight house. So tight, that it only needs a humidifier when no one is in the house.
The 6 only puts 1 quart of water/moisture into the air per hour of its run time.
01-04-2011, 08:36 AM #8
Just get the 12 gallon model and you can't go wrong.
It's only going to add humidity until the demand is satisfied.How tall are you Private???!!!!
01-04-2011, 04:56 PM #9
- Nov 2010
- Western Mass
- 21
Make sense guys thanks. Everything is pretty well sealed up hvac wise and as far as i can get now untill i can swing new windows. No big issues with them other than the one guy though. Thats good to hear, any other options out there for remote mount?
01-04-2011, 05:41 PM #10
Before you install this humidifier, make sure to test how hard your water is. If it's too hard, the element will burn up in less than a year. I only installed three of them when they first came out and ended up replacing both of them. Honeywell has a test kit for water hardness so you'll know if there is anything you need to do before you install it. I wouldn't even consider the 6 gal., I'd go with the 9 or 12 gal.
01-04-2011, 09:19 PM #11
- Jul 2010
- Caledonia,Ontario,Canada
- 404
I don't think they come with the test strips anymore. Two things I would like to point out is the larger the size the more hydro consumption(which you will see with any steamer), and if anything with the board goes wrong bye bye replace the entire unit. Out about 15 units we have had to do this for two units in the past year !!!
01-04-2011, 09:42 PM #12
01-05-2011, 06:53 AM #13
- Nov 2010
- Western Mass
- 21
