Results 1 to 13 of 14
    Victoria,Tx
    Exclamation
    My compressor dome started leaking refrigerant. It was rust from moisture under the metal information tag on top of the compressor. I ground down all the rust, then heli-arced a 4"x4"x1/8 SS plate to the dome. Replace the drier, added 4oz. oil, evacuated and charged the unit. That was 3 years ago. At the plant these nomenclature plates are removed to prevent this type of corrision. We also have a real problem with corrision under insulation.
    [Edited by oroy54 on 03-09-2005 at 12:15 PM]
    Cincinnati
    Sounds like something I would do.
    Tyler, TX
    Not recommended, but been there, done that.
    RSES Certificate Member Specialist
    Southwest Regional Association of RSES Secretary, 2017
    Victoria,Tx
    Hmm bwal2
    I was at first worried about degradation of the oil, but since the leak was on the dome, I said what the heck, the unit is only 10 yrs. old. Damn a poor man. Roy
    Tyler, TX
    Flowing nitrogen reduces oil degradation, and reduces explosion risk, but does not eliminate it.
    Long ago, I sawed a little compressor open to see what was rattling.
    It had a loose screw inside, so I tightened it up, then brazed the dome back on.
    It was still running & cooling when I got rid of it years later.
    I would not do or recommend such a thing today.
    Maybe I'm scared of dying.
    Victoria,Tx
    bawl2
    Hey that was great. I will find the time to cut a compressor in half myself! Thanks!
    Tyler, TX
    Re: bawl2
    Can I watch?
    Actually, cutting one open is not a bad thing to do.
    I routinely have my students take one apart every semester. Sometimes with a new one, sometimes with old.
    It does help with understanding the machinery.
    Putting a torch on one... nope.
    Just not a good idea.
    Oil + Heat + Oxygen = sad singin' & slow walkin'
    Grottoes VA
    Originally posted by bwal2
    [B
    [/B]
    How do you cut them open without getting shavings everywhere?
    I cut failures once and a while to see why they failed.
    Tyler, TX
    [QUOTE]Originally posted by karsthuntr
    Some compressors have a swaged, then welded, dome.
    If the swage is long enough, you can saw just through the outer layer, right beside the weld.
    The filings stay outside.
    Others have the half-domes turned out in a sort of flange.
    The weld can be ground off fairly easily.
    Drain the oil & flow nitrogen.
    I know a man that had one blow up in his hands.
    The weld can be cut on a lathe, if you know a machinist.
    That's how Trane does autopsies on warranty compressors.
    Rapid City, SD
    I feel sorry for that machinist! Them things are heavy enough to carry into the shop to cut, much less chuck up in a lathe. :-)
    One of these days I want to tear apart a compressor, just need a bit more free time.... and a compressor lol.
    Victoria,Tx
    Hmm The leak
    You know I dont think the leak would of ever happened if the sweating suction line wasn't passing right across the top of the compressor. Then the nomenclature plate location is still a bad design. This brings us back to a post a number of months ago about "Sweating compressors.
    Victoria,Tx
    Hmm The leak
    You know I dont think the leak would of ever happened if the sweating suction line wasn't passing right across the top of the compressor. Then the nomenclature plate location is still a bad design. This brings us back to a post a number of months ago about "Sweating compressors".
    Tyler, TX
    Buy it a nice long sleeve v-neck cardigan.
    Maybe that would help.
    My favorite was the AH model Tecumsehs with the suction line directly above the terminal cover.
    Dirty filter = Wet terminals.
    Nice!
