Page 1 of 4 1234 LastLast
Results 1 to 13 of 47
Thread: MANOMETER
    NJ
    Hello guys.
    I comparing manometers. The range varies from 5psi, 15,30, and 100 psi. The brand is SPER.
    What range do you think I should get.
    To be honest, never needed more than 3.5" WG lol
    I would appreciate your input very much.
    THANK YOU
    Apr 2004
    manometers dont read in PSI.
    NJ
    UHH I KNOW I'm TALKING about THE RANGE OF THE INSTRUMENT
    Jun 2000
    WYO
    I would recomend safety goggles when you make your purchase. My son has a used paintball mask for sale. Intrested?
    never say never
    Apr 2004
    Yeah I saw that, and you said "The range varies from 5psi, 15,30, and 100 psi."
    Jun 2000
    WYO
    No your yelling. listen to Doc.
    never say never
    NJ
    Some of you guys are great on here, but most of you are numb unts.
    You guys should chill.
    I read some of the posts on here and going by that you guys are not exactly a bunch Issac Newtons are ya?
    I don't wanna know.
    never again
    Grottoes VA
    ^^^^^^^^ What's his problem? ^^^^^
    Jun 2000
    WYO
    I dont know Doc. ????
    never say never
    Nov 2001
    Hungry,
    Your a student, I wouldn't come on here, bad mouth a professional member and ask about something that is used to indicate inches of water colum, and ask it's range in psi.
    As doc as said , without being a numb nut, they don't measure psi.
    You don't need to be defensive, if you mean something else
    ask it, or stay a student and stay HUNGRY.
    If you try to fail, and succeed.
    Which have you done ?
    Hungary
    Considered a digital manometer? I'd get the Testo 506-3 if you don’t own anything else and $165 is in your budget. I like because its quick easy and no fluids.
    I think the dual range (low to 4 WC and hi to 80 WC) covers most of your need - even has a pitot tube option. 3 decimal places on the low scale (that’s no the accuracy of course).
    The units of measure are anything you want about and easily selected on power up.
    It does have PSI. Check out the web site.
    I was going to go Dwyer and a get real manometer but decided it would pay for itself over time.
    Jan 2005
    Gilroy, Calif
    Nice response Hoffa. Thanks for picking the ball up!
    5,000 ft
    Get a Dwyer, I have had mine for about 7 years. Look for something that will read at least 20" w.c. Mine will read up to 20" w.c, and can select scale if I need PSI, Mbar, pascal etc.
    I usually use "w.c., or pascal when I check house pressures.
    4 pascal is easer to understand/explain to a customer (when dealing with house pressure) than telling them .016"w.c.
    You'll need more than 3.5". You may want to check pressure drop across hea t excahngers, duct system static pressures, pitot tube readings.
    Also get a dual port so you can read total pressure as well. Also look for a resolution of 100th's (0.00) for the low end readings.
    Steve
