Results 1 to 8 of 8
    Apr 2003
    arizona
    does anyone have any info or articles about laser themometers ? I need an article that is official an explains that they measure surface temp.. thank you..
    Jan 2002
    Ft.Worth,Tx
    Lightbulb Terra
    terrauniversal.com
    infrared/thermometer
    "Everyday above ground, is a good day".
    "But everyday that you have made a difference in someones life, may insure you stay above ground a little longer".<aircooled>
    After reading it, write one on how they should be used for chalk blocks for your van when parked on a grade.
    LOL....they do make for good chocks. I have seen many and owned a few and don't really like them. For me tenths of a degree are important in refrigeration and those infrared deals are not good enough. I prefer thermocouple probe or probe thermometers.
    small island in the Pacific Ocean
    I have one from Snap On that works great. I use it for supply air temps off grills, ceiling diffusers, sometimes compressor heads and breakers in panels. My van gets regular service so I have never had to use it as a chalk block but would think it too small for that application.
    Houston,Tx.
    I have one I use for cooking works great!! lot better than the old finger test for water or grease, Man can I cook some great fried chicken now I used to always have the grease to hot.
    "The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth".
    Works great on slab leaks. Dont care for it on air temps, to broad a spectrum.
    5,000 ft
    I have a Fluke. Great for finding overheating controls, breakers, disconnects.
    I carry a black permament marker so I can mark a target area for items that have a low emistivity, such as flues, copper refer lines etc.
    Know and understand your distant to spot ratio, this is where the complaints come from when accuracy is an issue/concern. It's a great tool.
    Steve
