    Hmm
    Can a thermostat be adjusted to turn a furnace on when the temperature drops two degrees instead of one degree?
    I would much rather a single-stage turn on and stay on longer than shorter, more frequent cycles.
    Indianapolis, IN
    Depends on t-stat.. High end & pro's like VisionPro's or Chrono's can but if you have $10 homeDecheapo, or mercury t-stat i doubt it....
    Brian
    Tyler, TX
    anticipator
    RSES Certificate Member Specialist
    Southwest Regional Association of RSES Secretary, 2017
    Thanks for the information on the thermostats.
    I'm hearing so many different opinions on single-stage vs. two-stage furnaces that I'm not sure what to do. The price difference is $600 and this would take us much longer to recover in savings, as it's just the two of us and we're gone during the day.
    From what I understand, the longer a furnace runs during a cycle, the more efficient it becomes (up to it's AFUE of course). If we can put up with the temperature dropping 2 or 3 degrees before the single-stage furnace kicks on, this might be more efficient for us in the end.
    Indianapolis, IN
    If $600 difference btw 80% and 92% hi-eff var speed air handler I would go for the 92%. $600 would be very close to the cost.
    Normally, i was told to set anticipator value to:
    .3 - for electric
    .4 - for single stage gas
    .8 - for heatpump & 92%+
