Results 1 to 13 of 15
Thread: CGWD Manual
    Oct 2007
    Eastern N.C.
    CGWD Manual
    Does any have a IOM or troubleshooting manual for the Trane CGWD050. I could not find it on tranes web site must be to old.
    Thanks PJ
    If you fail to plan, you are planning to fail ("Coach Dave")
    Hello I must be going. I cannot stay, I came to say , I must be going.(Jeffery T. Spauldlng)
    could not find IOM
    true knowledge exists in knowing that you know nothing.
    Dec 2009
    Southern US
    Found the manual but the one I found is I think in spanish.
    The manual number is CGWD-IOM-1. Maybe someone can find it in english unless spanish works for you.
    I'm good at making things cold...You can ask my first two wives!
    happy reading and happy new year!
    Oct 2007
    Eastern N.C.
    CGWD
    Thanks for the info. Is there a way to disconnect one of the compressors without getting a phase loss taking out both compressors in that circuit?? I'm getting a high amp on compressor d and want to disconnect it till the problem is resolved
    Quote Originally Posted by PJ's cool-aid View Post
    it depends on which compressor you call 'D'. most of the time you can just remove the wires between the compressor and the contactor.
    ofcourse not!
    that would be too easy!!
    on a carrier 30 series chiller you just go to the panel and disable it!
    providing that it is even working? LOL!
    Quote Originally Posted by jayguy View Post
    Oct 2007
    Eastern N.C.
    when I take the wires off it sees it as a lost phase fault. D compressor is the 10 ton in circuit number 2. I have set to be the last one called for but when it does call it locks out c and d both in circuit 2.
    ottawa canada
    Dissconnect the contactor coil wire and leave the power wires on , you should just get a contactor fault code then if my memory is good .
    N.E. IA
    Here you go
    Attached Files Attached Files
    "Wheel" mechanics work on "Wheel" chillers
    Mar 2013
    Richmond, Ca
    Outstanding. Made my life a lot easier, thanks rt
    Sep 2013
    Why cant I open your attachment?
    N.E. IA
    Quote Originally Posted by m597 View Post
    I have NO idea. I barely know how to even attach an "attachment". Let's see if I can figure out how to attach it again. Note the last one was almost THREE years ago. maybe it got "OLD" like me L.O.L.
    Just realized, when you click on the attachment, it opens a dialog bar at the bottom of the page. You have to click on what you want to do with the attachment. "Save", "open" or ???????????
