    Jan 2010
    Dampen Noise from Air Handler
    We have a small air handler for a bedroom upstairs. The air handler is in small nook in a closet in the bathroom. The entire upstairs bedroom is above our kitchen. The air handler is mounted horizontally on is resting on a few cinder blocks.
    When the air handler operates, we can hear its running noise in the kitchen. It sounds somewhat like a 60 cycle hum. Is there a way to dampen the noise of the air handler by resting it on foam, etc. rather than on directly on the cinder blocks? Should the handler been hung from the roof trusses?
    Thanks,
    Dave
    Jun 2010
    Philadelphia PA
    sounds like you have begun to solve your problem. Having the unit sit on cinder block will certainly transmit the unit noise
    Mar 2010
    Vibration isolators work pretty good. Quick and easy to instal
    Jan 2010
    Quote Originally Posted by senicalj4579 View Post
    Is there a specific type of vibration isolator you have in mind?
    Thanks,
    Dave
    Jun 2010
    Philadelphia PA
    Start with the simple rubber-cork pads. Also there is what is called break-out noise so try some drywall under the unit with some insulation batt on top to catch some of that
    Jan 2010
    Quote Originally Posted by genduct View Post
    Thanks!
Tags for this Thread
