Results 1 to 13 of 13
    What is the recomended temp to set attic fans to come on at. I have mine set to 80dF and I live in Georgia. Is this to low ?
    AB
    Cincinnati
    It'll probably never shut off when it starts to get hot out. I would say 100-110.
    South Carolina
    100 to 110 is what I set them at
    90 to 95 degrees is in most of the manufacturer's guidelines and instructions.
    Connecticut
    Not that they do any good anyway...........the attic is still hot as hell.
    I wish there was a cheap way to get the temp of an attic where it is bearable to work in one.
    They make little portable ac units.
    Cincinnati
    I work in attics naked. It keeps the homeowner away.
    Studies have shown those fans are a waste of electricity.
    Doncha private parts get itchy Matt?
    Hey cockroach, don't bug me!
    Cincinnati
    My wife keeps them safe for me in her purse.
    I think thats her vibrator.
    newton,mass.
    Hey lets get it straight, is the vibrator or Mattm's private parts in the attic ?
    "Nothing else can poison our culture, corrupt our society or ruin the character of our people like unearned money or unearned opportunity." -- James R. Cook
    "Fooling around with alternating current is just a waste of time. Nobody will use it, ever." Thomas Edison, 1889.
    I installed a humidity 1-wire network sensor and temp sensor in the attic and installed the same outside.
    I have the attic fans on computer control.
    First I watched the attic temp rise as the temp outside got hotter. then i turnd on the fan and saw a drop in the attic temp.
    So I created a short program that monitors the sensors
    if the attic temp is 10dF higher then the outsid temp and the temp is higher than 80dF turn on the fans.
    Monitor the humidity in the attic and outside if the attic humidity is higher than outside humidity and ithe attic humidity rises turn off the fans.
    if the temp in the attic rises above 195dF than there may be a fire so turn off the fans.
    Now I think this may be a better way to do the Attic Fans but I do agree ridge vents would be better but the design of my house does not allow for this.
    AB
    That's why his wife has the vibrator, he can't get it straight.
