Results 1 to 13 of 27
    Thumbs down
    I'm having a problem with condensation. The combustion chamber keeps filling with water and no the lines are not plugged.And the furnace is level. It will run for about 3 days then fill up and quit working.
    [Edited by alpo8484 on 03-04-2005 at 09:10 PM]
    Mar 2002
    Northeastern Illinois
    By any chance is this installed horizontally?
    If it ain't broke don't fix it!!
    No it is not
    In a van by the river
    Is there a condensate pump for it or does it drain direct. If pump may want to check operation if you haven't already
    ## + years in the field never made you a know-it-all This industry is far more diverse than you are
    Mar 2002
    Maybe a little more details.........Or is it a secret.What furnace do you have? Is it upflow,downflow? Obviously,it is a 90+ if it condensating.Fill us in.
    Assuming it's a 90+% furnace
    It's a rgra 120 upflow and it's no secret. I disconnect the drain system pressure switch the vent motor will run but won't fire obviously.As soon as i hook it up every thing shuts down
    Seattle
    Hmm Full of.......Water
    Alpo8484.So how is the furnace mounted?Up flow,down flow,horizontal left,horizontal right. Make and model number of the little rascal.I'm going to assume it is a ninty plus percenter.If its not we may have some REAL issues here.And if you will what exactly do you mean bythe combustion chambers are full of water? Any info you can give would be helpful on this end.
    Thank.41Gasman
    Yes it's a 90+ sorry for not be specific I thought everybody would know, my bad. It fills up with water in the chamber behind the vent motor
    Mar 2002
    Everything shuts down,you mean the whole thing. The ID blower quits running? The "drain system pressure switch" you speak of,is this connected to the ID blower?
    No it runs through the safety's then to gas valve
    Mar 2002
    Do those furnaces have a resevoir of sorts that the ID blower mounts to? If so maybe the hole for the drain never got punched out[factory]. Maybe some PVC filings got washed into it.
    34.8n 102.4w
    Re: Full of.......Water
    Thank.41Gasman
    Thank you for reformatting.
    Life goes on long after the thrill of living is gone.
