Results 1 to 13 of 13
    Feb 2005
    Equipment without doing what first ? How do you guys start a start-up,and what do you feel are the most important things to verify.
    fan,heat & ac works
    Gas pressure
    installed to codes
    filter installed
    supply air temp
    ruturn air temp
    make sure adequate air is coming out of each supply register
    explain operation to homeowner
    amp draw between r & w
    amp draw between r & y
    superheat
    thermostat mounted right
    no tip
    I could go on & on fatt eddy is this ok for you?
    Jan 2005
    for heat it all electrical conn ,filters, belts ,operation of safties& heat x condtion,control of system,tstat or ems.
    a/c elec conn filters belts operation of safties compressor oil,charge condensate condser coil evap coil condition & control.
    Nov 2001
    If she's married,
    then look at co
    If you try to fail, and succeed.
    Which have you done ?
    So did you learn anything fatt eddy.
    Feb 2005
    Yep
    Glad we could help.
    Feb 2005
    With what?
    Showing you how to do a start-up.
    Jan 2005
    Talking
    No comment.
    Feb 2005
    *biting lip*
    I would take some of that $3000,00 tip and hire someone that knows what a start up is
    Me to.
Comfortech365 Virtual Event
