Thread: replacing
    replacing a unit,can I put in the same size unit I'm replacing and line sets?
    SE Michigan
    It would be helpful to do a load calc. to see what size you need. Also a higher seer may be in order depending on where you live.
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    Yea, but you should have the houses load checked to see if thats the size you really need.
    Have you added any insulation, or upgraded any windows or doors.
    If so, you may be able to use a smaller sized unit and save money.
    beenthere is right plus in most area their was all of homes over size to begin with.
