Results 1 to 6 of 6
Thread: CSL
    Dec 2010
    La Honda, CA
    CSL
    Anyone got any opinions on the creosote sweeping logs is see for wood stoves. I sweep my flue myself about every two years and would much rather throw a log on the fire than climb up on my slippery roof and run a brush through the flue.
    May 2005
    Madison, WI
    Its not a replacement for manual sweeping. It believe what it does is break down or dry out the really nasty stuff so that it can be swept out easier.
    pulaski ny
    they make a powder that's supposed to work better. i still sweep every year. chimney fires can be nasty. and extinguishing can be verry messy.
    S.E. Pa
    Thumbs down don't waste your money
    These logs can only modify the creosote into a form that can be mechanically removed such as brushing. I've never seen one of these logs inspect a chimney either....
    Dec 2010
    La Honda, CA
    Thanks all,
    It sounded too good to be true. Unless I read the instructions wrong they imply that theres no need to sweep anymore (I wonder how many people stopped getting their chimneys swept?). Didn't seem like a good idea to me (hence the post). I don't work on wood burning appliances just Nat gas and LP. Thanks again for the responses, looks like I still get to play Spider Man on my roof this spring.
    Jun 2011
    Charlotte, NC
    Agree w the above. If you have a catalyst in the wood stove, burn it w/out the catalyst in there. They say they are safe/fine for the catalst & to bypass them, but the mfgr said to remove it so that is what I do
