Results 1 to 13 of 14
Thread: Model #
    Question
    Very simple question, but I am stumped. Where do I find the model number for my Lennox furnace? I have found a model number on the ignitor, but I don't think that is it. Any help would be greatly appreciated.
    Mar 2002
    Richmond, Virginia
    Depends on the furnace. If gas it's inside the burner compartment behind the top louvered door.
    No manufacturer places their model # on a removable door, I don't know exactly where it is but look somewhere that is not removable.
    on the inside cabnet on the left or right hand side.
    In a van by the river
    Fatty you're wrong, a lot of manufacturers have their specs where HVACPRO specified, meaning remove louvered door and look on right side more than likely
    ## + years in the field never made you a know-it-all This industry is far more diverse than you are
    Don't think so,
    and don't think thats what he said,
    Did you say it was on the removable door?
    Now git er done, U know better than that.
    Did he say it was on the removable door?
    Git,
    Thats my post, the guy was looking for the model # I was just telling him to not to waste time looking on a removable door because they don't put em there.I didn't say that anyone was looking on a removable door.
    I've read it over and over and I see how you perceived it. It would be correct if it's behind it with panel on but incorrect if it was behind it when remove.... I forgive, do you?
    No problem, I do have a problem expressing myself in words it always comes across the wrong way,
    Yes it does.
    Same here
    Mar 2002
    Richmond, Virginia
    git-r-dun, you interpreted my reply right. Now don't let eddy brow beat you! I never said the nomenclature was on the door. I didn't think I needed to give the HO step by step directions but let me try again just to clarify things a little. . Approach the machine. Remove the top louvered panel (assuming the equipment is in the vertical position.) Place this panel aside. Being very careful and with a strong light source peer into the area where you see controls, wires, pipes, switches, valves, etc. Focusing your attention to the left & right inside vertical panels (the ones that run perpundicular to the part you are looking at) you should see a white label approximately 6 inches high by about 4 inches wide. On this label you will find model and serial number. Please do not waste your time looking at the panel that you set aside. It won't be there. Better?
