Results 1 to 4 of 4
Thread: Thermostat not responding
03-03-2005, 09:32 AM #1
- Mar 2005
- 1
My Honeywell Chronotherm IV Plus programmable thermostat appears to be stuck. No matter what temp I program, the thermostat will not read higher than 66 degrees. However, the furnace is producing heat.
03-03-2005, 11:23 AM #2
- Jun 2004
- 956
if it is fact higher than 66 degrees than get a new stat
03-03-2005, 05:12 PM #3
Measure the temperature near the thermostat with another thermometer to verify that it is indeed 66°. Unless you're experiencing extremely cold weather there you should check your air filter to be sure it is clean. If it is you should call a service company and have your system checked.
03-04-2005, 08:00 AM #4
Put a lamp or another souce of heat under it and see if it rises.
