    Atlanta, GA
    2nd stage thermostat setting
    Hi All,
    We have a GMH950703BX model goodman 2 stage propane furnace. I have replaced the thermostat but I am unsure if the 2nd stage is working. How do I confirm this and set the thermostat for the proper 2nd stage settings? The thermostat is a trane.
    Here is the manual..
    http://link.schlage.com/Products/Doc...r_manual-c.pdf
    I have it enabled, just not sure if I need to modify any other settings and how to confirm it's working.
    That furnace times to high from 1 to 16 minutes after starting based on previous cycles. It's the only furnace on the market that won't let you hook up a 2 stage stat to stage based on house needs. You can only use a 1 stage stat or 2 stage stat wired with only 1 stage hooked up.
    It is a neat lookin' stat though.
    Cincinnati, Oh
    unfortunetly, true :-\
    "Just get it done son."
    Dad adjusted
