Thread: silver brazing
    Feb 2005
    Can you use 75% Argon 25% Co2 to purge ref lines while silver brazing? This is the gas that mig welders use.
    Nov 2001
    Co2 is a higher cost then nitrogen,
    Why use it, if it cost more ?
    You don't need the high pressure gas,
    If you try to fail, and succeed.
    Which have you done ?
    Tyler, TX
    Yes, you can use it, but nitrogen is cheaper.
    RSES Certificate Member Specialist
    Southwest Regional Association of RSES Secretary, 2017
    Feb 2005
    silver brazing
    Thank You for your answer toolpusher and bwal2.
    I am not using it. I saw a vet. HVAC serviceman using
    it and was wondering if it would put moister in the syst
    em.
    pipe threader
    burlington county n.j.
    wouldn't the oxygen in co2 cause oxidation you are trying to eliminate with the nitrogen?
