Results 40 to 52 of 61
03-05-2005, 09:52 PM #40
- Feb 2005
- 58
Wow, thanks here ya go
I am in Lebanon Tennessee, about 17 miles east of Nashville, zip code 37087
I was wondering about the comments about sizing of the units and so I did some looking around and based on our size how far off are we?
Our Downstairs area is about 2675 heated, and upstairs is about 1250 sq ft heated. All Wood floors, 2x4 framing with brick and stone outside, R13 in walls, R30 in the attic. The windows will be either Pella or Sun Windows, Wood Double hung, aluminum clad, argon gas, Low E insullated which are the top end windows. We do have quite a few windows and french doors. We have a raised foundation with an aproximate 3' clear underneath. 2 fireplaces, 1 36", 1 42" both wood burning manufactured design with glass doors.
I decided to use 5/8" drywall. 9' ceilings in both the upstairs and down stairs (10' in my office area).
Like I said, I have seen this builders quality and he is top knotch. If anything, we are over designing for efficiency in the area, but that saves money, right.
I appreciate everyones comments, I am the first to stand up and say I do not claim to know about this stuff, only what I read and the specs..
So, perhaps you guys can look at the sizing again for me and I will go back to the contractor.. and any ideas on usuage costs would be wonderful.
By the way, I have the drawings on disc and can email the floor plans if needed.
03-05-2005, 10:20 PM #41
- Apr 2004
- Niantic, Illinois
- 545
I may have mispoke, I realy can't accuratley comment on the size without personaly running a load calculation either from a print or in person. What I can do is based on your specified size and heating hours and cooling hours and kw/hr. I can give you an estimate on energy usage. I have lost track throught the post though. Are these heatpumps, dual fuel heat pumps, or gas heat plus a/c systems? and if anyone knows the degree hours this will be helpful, I can't find my map that shows each area's hours of operation.
03-05-2005, 10:46 PM #42
- Feb 2005
- 58
units
All units will be heat pumps, the down stairs one will be a dual fuel, electric/propane design Like I said before, the first design ws with a package unit but now were going to a split system down also. The upstairs units will be heat pump but no gas.. hope that helps. I appreciate your help, I have the plans scanned in and can email them but I am not sure if you will.. let me know.
Dave
03-05-2005, 11:04 PM #43
- Apr 2004
- Niantic, Illinois
- 545
Downstairs is a 5 ton dual fuel system, upstairs is 2 ton heatpump, studio is 2 1/2 ton heat pump is this correct? I am currently looking for my degree days map, should be able to give you energy usage info tommorrow. I can run a load if you like, my email is: berad@mchsi.com
03-06-2005, 07:26 AM #44
- Feb 2005
- 58
Sorry I crashed a little
Down stairs is the proposed 5 ton heat pump, dual fuel split system, the upstairs of the house is the 2 1/2ton split system and then the studio is the 2 ton system.
Like I said before, I like the variable speed air handlers that are available on the market.. looking at the trane systems they have a standard single speed handler and then the upgraded variable speed.
I know I am going to upgrade from the "Builder Model" units and it will be interesting to see what the calcs come up with on seer's. I can list the equiptment that is proposed if necessary as well.
One of the oontractors (the one my contractor likes best) is strictly a Trane guy.. the other offers American Standard, Carrier and Goodman. I am not really looking at Goodman to put in, I had one in my last studio and the control board fried in 2 years.. were very rude to deal with!
So, hope this all helps. Like I said,I'd be glad to give you a call, I really enjoy learning as much as I can on this and if talking on the phone makes sense let me know how to contact you.
Dave
03-06-2005, 08:25 AM #45
- Feb 2005
- 58
All 3 untis are heat pumps,
Sorry, I was not specific enough. All the systems will be heat pumps, the upper floor and the studio will have electric heaters not gas..
Dave
03-06-2005, 08:33 AM #46
Banned
- Aug 2002
- Office and warehouse in both Crystal River & New Port Richey ,FL
- 18,836
Your contractor may be basing the system size,more on the heating needs ,than the cooling.
In a very dry climate ,I've heard of this being done,larger system,less need for backup gas or electric.
However ,in a humid summer climate ,the cooling will be oversized,and indoor humidity will be too high and uncomfortable.Can also contribute to the growth of mold.
When you ask about the loads,see if it's being sized for heating or cooling.
He also could be unaware of the type windows being installed,and used a more standard in the calculation.
03-06-2005, 08:39 AM #47
- Feb 2005
- 58
Ok, One More Question
In our original quote we were using a package dual fuel system (trane 1200), but now, we have decided to go to a split system, so, does that mean my dual fuel system is out? I am not sure if now the air handler has a gas heater side. I don't really want to go all electric on the 5 ton, I'd still like to have a dual fuel aproach, can I?
03-06-2005, 09:57 AM #48
Banned
- Aug 2002
- 18,836
You can,if the location of the furnace allows proper venting,etc..
03-06-2005, 10:37 AM #49
- Feb 2005
- 58
All the comments and suggestions are great
Thanks for the reply, I will make sure the HVAC guy knows about the windows.. Hey, if I can reduce size, great, less cost to buy, less cost to run. I will get with them perhaps this week and discuss the loads..
I did mention to the HVAC guy that for the downstairs I'd rather have more heat so that is why we went to a dual fuel option, this house has it ,and it's nice when needed, although, who knows, perhpas the heat pumps today can actually heat enough with out the gas, but when the temps really get down (this year to 9degrees) it will be nice to have a back up..
I'll mention the potential over size of the air concern, that was an excellent point about humidity.
We moved here in May from Southern California, so, the weather is completely different than what were use to for sure..
Dave
03-06-2005, 09:46 PM #50
- Apr 2004
- Niantic, Illinois
- 545
Ok, here goes nothing! I started another thread toget the operating hours. I don't work on heatpumps much, I'm farther North. I'm going to assume 50/50 operation between back up heat and heatpump. starting with the cooling at $.06/kwhr and 1616 operating hours per cooling season. The 5 ton 10 seer will cost approximately $582. per cooling season, 5 ton 12 seer approx. $485. per cooling season, 5 ton 14 seer approx. $412. per cooloing season. Now for heating I'm assuming 100,000 btuh furnace for the backup heat on this unit, operating for half of the 3729 heating hours and $1.10/therm of gas. An 80% furnace will cost you approx. $2033. for it's share of the heating load. I have to say though, that seems like to many heating hours for your area, but that's info I've been given and it will give some base of comparison. Anyway, 90% furnace with the same parameters will be approx.$1797.Now for the heatpump portion of the heating cost, again at $.06/kwh and half of 3729 heating hours. 5 ton 10 seer $671. 5 ton 12 seer $560. 5 ton 14 seer $475. This is the info for the first system. As I pointed out I don't think you have tht many heating hours, that is more than I have in central Illinois, and you're gas rate may be different and the balance point of the heat pump is closer to 70/30 rather 50/50 from what I can ascertain. Again, I apologize, I'm not a heatpump guy, very few of them in my neck of the woods.
03-06-2005, 09:58 PM #51
- Apr 2004
- Niantic, Illinois
- 545
Now for the 2 1/2 ton system with strip heat backup. Under the same parameters as before. 10 seer for cooling $291. 12 seer for cooling $243. 14 seer for cooling 206. The electric back up will be the same parameters of a 50/50 split. Assuming 10 kw heating the back up will cost you approx. $1120. The heat pump side for heating will be as follows, 10 seer for heating $336. 12 seer for heating $280. 14 seer for heating $238. And the smaller systems numbers will be marginaly smaller than these but equal in proportion. I know this exercise wasn't very precise, My numbers are much closer when dealing with split system a/c and gas heat in my own area where I am familiar and informed, but I hope it gives some basis for your comparison.
03-06-2005, 10:37 PM #52
- Feb 2005
- 58
Berad, thanks, couple of questions for you.
I really appreciate the work you put in to this, I did see the thread on the heat and cooling days, and I did go to the site via the link. Im not sure how thoes numbers get calculated either.
Now for a couple of stupid questions.
1. The "Season" use, is that the total amount based on the numbers from the chart and do I assume that would be for per year? (not per month)?
2. from what I have seen in this house the secondary gas hardly kicks in at all unless we get below 30 degrees and that would also depend if I tweek the thermostat a little warmer. Your probabaly pretty close on the cost of fuel, I think we probably average $1.10 per gallon here recently. I know that at times it is quite a bit higher but we can get a level pay plan that would probably averate the $1.10 costs.
It seems pretty consitant the savings are about 30% from the 10 to the 14 seer which seems pretty good, even better than the Mfg specs, but, its still minimal overall vs. the cost of the upgrade (ok Im not going to get in to the price issues).
It will be intersting to see what our electric bills end up once we get in.
With the new specs for the EPA going to 13 this coming year it will be interesting to see if the units get more competitive as more units get changed over. I'd probably be happy with a 12 SEER, or possibly a 13 seer unit just to be up with the EPA.
Now given your comments about the heat pumps, I wonder if anyone else will chime in on the figures on heat pumps.
I really appreciate all the work you have done, if your ever in the Nashville area I deffinetly owe you a lunch.. thanks so much for taking your time and taking the effort to provide me with some numbers to work on..
Dave
