Page 4 of 6 FirstFirst 123456 LastLast
Results 40 to 52 of 71
  1. #40
    SC
    Very nice!
    I like the attention to detail. Even turned the writing on the metal to the inside.
    I'd be proud to have that in my house.
  2. #41
    the exhaust is more than 12" away from the window, per code
    i pitched the furnace toward the front but not to the right, it's running and draining beautifully with no error codes
    thanks for the comments
  3. #42
    thanks gevans!
    i did that with the metal and the pvcs cause i HATE to look at the writing. i also removed all the lame stickers for that "clean" look
  4. #43
    Mar 2010
    North Ridgeville, Ohio
    well it does look like a good install and you definately spared no expense with the choice of equipment
  5. #44
    Sep 2009
    Arnold mo
    Quote Originally Posted by cody350 View Post
    12" under a window is code? I'll take your word, but that just seems like a dumb code.
    An answer without a question is meaningless.
    Information without understanding is useless.
    You can lead a horse to water............
    http://www.mohomeenergyaudits.com
  6. #45
    Nov 2010
    Dallas, Texas
    I wish we had basements here in Texas... Looks pretty good.
  7. #46
    Aug 2010
    Marshalltown, IA (The new rainforest)
    I do like the job! I wish I had a nicer basement but I love that the SLP98 can allow me to install on a return riser so I can get the filter out of the water flow.
    "It's not an OLD unit, it's a testament to old school manufacturing of quality over quantity." http://i292.photobucket.com/albums/m...608_092209.jpg
  8. #47
    Outside The Motor City
    Nice job , If I had to nit-pick I would like to see some transition connection between the plenum and extended plenum ducts.
  9. #48
    Aug 2010
    The nice thing with the SLP98 is that you can pretty much get away with murder as long as you size everything based on a 0.8" w/c. If that were the case then the ECM will rock the hell out of improper ductwork. I did get to see one of those put on a system with a total SP of 1.1" w/c and it actually ran properly...I love that about ECMs that you get some wiggle room. Granted, in my house, I'm just basically going to throw in a new return drop, new plenum, and make the unit sit on top of the return plenum so I can get it up out of the mud and water flow through my basement and install the filter door so I can get that to work, also I'd love to get the EAC, but I'm not sure where I'd install it in the chain
  10. #49
    May 2010
    Great install! Great choice on equipment, the I comfort t-stat is a awesome
  11. #50
    Aug 2009
    Jurupa Valley, CA
    I think I'll go along with everyone else and say "I wish I had a basement". That unit wouldn't even FIT in the space I've got mine wedged in (in the corner of the garage).
  12. #51
    Pacifica, California
    Ah, I see a problem. In your last 2 picks there is white stuff all over the ground and on your roof. Where I live, that's a problem.
    Go the extra mile, it's shorter than you think. UA in the Bay
  13. #52
    Aug 2008
    Bel Air MD
    Good looking work, do you have any problems with the a/c draining with the furnace pitched forward like it should be and the evaporator coil facing back?
