Results 1 to 13 of 71
12-23-2010, 09:32 PM #1
- Feb 2006
- 507
my house, let the nitpicking begin!
Lennox SLP98UH070V36B
Lennox XP21-024-230
Lennox Icomfort
Lennox Pureair
Lennox Powered Humidifier
Lennox UV Lights
entire install done by yours truly
all duct near furnace redone (plenum, return, offset and radius boot all made by hand, by me)
almost all gas piping in home redone, due to being ridiculous
install still work in progress, need to hardwire uv lights and install condensate pump
let me know what you guys think
12-23-2010, 09:58 PM #2
Nice looking rig you got there.
UA LU189
10mm, because it's better than .45acp
12-23-2010, 10:02 PM #3
Pretty work
don't forget your drainline on the coil
and I don't like your O.D. Unit stand, I like to build them on a pressure treated deck platform then put snow legs on if needed.
But very nice work
12-23-2010, 10:57 PM #4
Very Nice.
12-23-2010, 11:04 PM #5
12-23-2010, 11:06 PM #6
Professional Member*
- Sep 2005
- North GA
- 17,287
Really CLEAN and neat install... I am sure in your area it fits all applicable codes... Down here we usually put a pan under the furnace regardless of where or how it is mounted. Just local stuff.
The orange T-stat caught my eye... Does Lennox make that or did you 'customize' that...
GA-HVAC-Tech
Galatians 2:20-21; Colossians 1: 21-22 & 26-27; 3:1-4; Romans Ch's 5-6-7-8
2 Chronicles 7:14
Quality work at a fair price with excellent customer service.
12-24-2010, 12:05 AM #7
- Mar 2003
- Saskatchewan, Canada
- 757
Wow great looking work, you'll enjoy this for years and years.
12-25-2010, 02:29 PM #8
- Aug 2010
- East Coast
- 20
12-26-2010, 08:37 PM #9
- Feb 2006
- 507
thanks
drain for the evap will be installed with the condensate pump.
i'd be curious to see to pics of your HP stand. this stand is from lennox built specifically for these HP's and i believe it looks very clean and is quite sturdy.
and thanks
thanks
12-26-2010, 08:39 PM #10
- Feb 2006
- 507
i didn't support the pvc on the vertical but it's supported every other floor joist on the horizontal.
thanks
never heard of using a secondary pan unless it's above a living space (attic). haha the orange stat is due to the lighting in the hall.
and thanks
thanks, you bet i will
12-26-2010, 08:50 PM #11
man ya'll nothern boys are lucky we dont have basements in this part of texas must be nice working in a basement. try putting the same unit in a three and a half foot attic when the attic temp is 160 plus i think im moving up north so i can make easy money. hey southernmech please tell me your joking about making condencer pad out of any kind of wood so do you go out and fix it for free when the condencer fall through the rotted base not trying to be a butt head just wanted to know if you warranty your work
12-26-2010, 08:57 PM #12
No, not joking, we build pressure treated stands just like a deck.Pressure treated lumber does not rot. Most of this is cause we are in a flood plain and the unit's have to be up to a certain elevation.
And no smart @ss we don't have to go and fix them, do you have to go fix your deck?
12-26-2010, 09:06 PM #13
LOL!!! i wasnt trying to get you worked up i understand about you having to build them up because of a fllod plain i was just asking and i poor concrete pads for all of my units and if you think that there is a material out there composite , pressure treated etc. that wont rott over time than smartt @ss your wrong.
