Results 1 to 8 of 8
    when checking ohms on a compressor the highest reading is between run and start, middle reading start and common, and lowest reading between common and run. is this correct?
    how does it read on the schematic
    R S C R S C
    C S R
    C S R
    R S C R S C
    what is the purpose of the run capcitor and the start capacitor?
    It's been many years since I have used this, but if I am wrong I'm sure there will be some people here happy to correct me.
    R to C = lowest reading
    S to R = Highest reading
    S to C = middle reading
    In general the two lowa should add up to the high (approx.)
    [Edited by fat eddy on 02-26-2005 at 08:39 AM]
    ohming compressor
    S to C = Highest reading
    S to R = middle reading
    Nope, you messed up eddy:
    thank you for the information, very usefull
    louisville
    I ohm out compressor windings ferquently and have never had any problems, but I'm sure I will now!
    LMTD,
    You said I was wrong then posted the same readings that I did go figure
    Fort Worth, TX
    LMTD,
    Eddy,
    Yours:
    His:
    Um... I see a difference.
    • Electricity makes refrigeration happen.
    • Refrigeration makes the HVAC psychrometric process happen.
    • HVAC pyschrometrics is what makes indoor human comfort happen...IF the ducts AND the building envelope cooperate.
    A building is NOT beautiful unless it is also comfortable.
    C and R - Lowest
    C and S - Low
    S and R - Highest and MUST be equal to the sum of the resistenace of C & R plus C & S
    Sorry LMTD,
    You were right my original post did state the wrong information, thank you for catching that typo. I have since edited the typo to reflect my original intention.
    Thank You,
Comfortech365 Virtual Event
