Results 14 to 24 of 24
Thread: Lennox 80 UHG
    Jul 2000
    NW IL.
    Is the model with spark ignition or the hot surface igniter?
    If it is the spark ignition there is a flame sensor upgrade kit for that series. Lennox P/N Dual rod flame sensor upgrade kit, 62K5001.
    The inducer blower wheel will pack up with dirt during its life. But before you clean the wheel check the amp draw on the inducer to see if it overdrawing amps.
    Originally posted by Toolpusher
    With an attitude like that on here,
    you might as well get used to talk'n to your self.
    Like you have been.
    If your so up on lennox, then you know that they do have support.
    So keep chang'n things and maybe we all can some day carry your tool bag,
    But on the way in the house I'd probably stop by my truck and get my meter.
    You are 100% correct, that was way out of line on my part, I just tend to get a little touchy when someone calls me a parts changer. I have only done this on my own personal garage heater attempting the "Quick Fix", I owe an apology to anyone offended and know that when I have the facts I can truly (hopefully) get the fix from Lennox.
    May 2002
    long beach ca.
    Angry
    Me say,get rid of magic fire box, you goum to forest and chop wood. Heap good fire.
    Jul 2002
    St Paul, Minnesota
    White man fenced off all the trees, putem up signs that say "NO TRESSPASSING." and in State/National Forests they got more signs "Don't do this, don't do that, can't you read the signs?" (what song was that from?)
    [Edited by MikeJ on 03-12-2005 at 08:55 AM]
    I have a wood burner in the shop! Why even bother?
    Really, after *ss chewings and eating crow I dug out the U-tube manometer and witnessed a 1.0 start cycle, .8 after fire, gradually dropping to .2 and dropping out. A little WD40 kept things going for a few days! Now that I know that ball bearings will drag, I still need to replace the CBM assy. What can I say? My Crystal Balls are dragging!
    Suppy NC
    the 80 uh and g24 had a run of bad inducers bushing hanging up on them. also presure swith to high .45
    order new inducer kit. it will come with a pressure switch also the new switch is set for .35 big differance
    the flame senser kit also should be installed for better flame signal and easer to clean. the circut board was also ub graded on this unit comes in a kit whith leads and all
    these are upgrades and not parts changeing
    just lenox will not addmit they screwed up on this unit and the g24.
    Jul 2002
    St Paul, Minnesota
    Just in case someone missed this.
    Niantic, Illinois
    Smile
    This brought to you by the makers of sevice experts
    No, what I really intended to start was a post of why no one likes to go home and do for themselves the same that they do for others all day long! Somehow it all went south for the winter! It's all yours from here!
    Suppy NC
    good point indian lol
