Results 14 to 16 of 16
    in a house, Appomattox, Va.
    In a vacuum you would have to depend on radiant heat emission to reject heat from the suit. No air or other medium to carry the heat away through conduction or convection. They might use an expendable refrigerant and vent it into space, like blowing freon on a coke can to cool it-one use only.
    The gold and other materials reflect the energy from sun rather than absorb it and greate heat gain. "shiny",light materials also don't radiate heat into space as well as dark,matte finishes.
    Col 3:23
    Earth
    Using body heat, to boil liquid oxygen for breathing may provide a viable refrigeration circuit. With the refrigerant (oxygen) being a consumable no condenser would be needed. If heat was required, maybe some form of chemical heat process was used.
    Jun 2001
    Michigan
    Then this will filp you out. Read the part carefull about depending on which side the suit faces to the sun, it can be damn hot, and the one facing darkness can be damn cold. Thats wild stuff.
    http://www.astronautix.com/craftfam/spasuits.htm
