Thread: Heil furnace
    Feb 2005
    Hmm
    I have a Heil furnace......when the target temperature is hit the furnace blower continues to run and does not shut off. I can even set the target temperature below the actual temperature and it still runs.
    What is going on with this thing?
    SE Michigan
    Make sure that the fan switch at the tstat is in the auto position. Other then that, you may have a bad relay, circuit board, or comb. fan/limit control and will need to patronize your local heating contractor.
    "If anybody can draw on the power, where do we put the meter?" - JP Morgan before pulling Tesla funding
    Doesnt shut off soon enough for YOU? or never shuts off?
    If I know I'm going Crazy,I must not be Insane
    Feb 2005
    Heil Furnace
    The blower will stay on always.......will not shut off unless I turn off power.
    I have checked the position of fan....it is in the auto position not the on position.
    Than you need to call for service.
    gasman Guest
    Smile
    either the relay switch stuck closed or the fan switch is stuck on fan/limit control.
