    I have a Lennox Innovator furnace that is not firing and I am looking for suggestions as to how to remedy the problem? The pilot is lit, and it sounds like the furnace tries to kick on but it never does. Any suggestions on what I should do?
    If it is a matter of cleaning a sensor, do I need a licensed serviceman to do this or is it simple enough that I could do it.
    Nov 2001
    I'm not sure what model that was,
    But it sounds like you should make a call.
    Which have you done ?
    Jul 2002
    St Paul, Minnesota
    A sensor senses something (flame) and if no flame it can not do it's job. Read the manual if you have one, when you get to the part about calling a service technician, pick up the phone and make the call. You are in over your head.
    Mar 2002
    Richmond, Virginia
    Innovator covered a large line of equipment. Innovator was changed to "Signature Series". It denotes top of the line equipment. I doubt very seriously there is a pilot in that furnace. Model number is the only way to identify it. Sounds like it's time to make that call.
    louisville
    Turn on the gas valve
Comfortech365 Virtual Event
