12-20-2010, 10:27 AM #1
- Mar 2010
- 7
Bryant Evolution program question
I've got a Bryant Evolution controller and need some assistance with a programming question. I've currently got the program setup with a WEEKDAY and WEEKEND programs that are working perfect for us. Well we are on holiday vacation for the next 2 weeks and wanted to run my weekend program during this time. I cannot use the HOLD or VACATION settings because it cannot handle the multiple temperature changes I want. So I decided to plug these settings into my ALLDAYS program.
So my question becomes, how do I remove the ALLDAYS settings when we go back to work so the system reverts back to the WEEKDAY and WEEKEND programs that have worked so well for us? I looked through the manual and I cannot see anything about deleting a program. I called several dealers in my area and none of them know how to do this, and they keep telling me I'm stuck with the ALLDAY setting and I will just need to go in an update to what I want each day. So I'm hoping there is someone here that knows how to program that controller to do what I want.
Thank you!
12-20-2010, 01:49 PM #2
Just go back into schedule and select WEEKDAY make adjustments then select WEEKEND and make adjustments. Then exit saving changes and poof you are done!
12-20-2010, 02:52 PM #3
- Mar 2010
- 7
Sounds to easy to be true! I did what you said and I'm assuming everything is working okay. When I go back into ALLDAYS mode I still see stuff in there, but I'm assuming it really doesn't matter.
12-20-2010, 05:31 PM #4
after changing weekdays and weekends exit. do not go back to alldays before exiting and you should be fine.
