Thread: Dual fuel
    Oct 2002
    Plano, TX
    Is there a reference or web link on "sequence of operation" that describes dual-fuel heat pump operations?
    Apr 2003
    Eugene, Oregon
    Dual fuel systems be it gas propane or oil back up heat depends on the system controlling it. If you have a "kit" for dual fuel you should be able to find the brand of kit and look it up. Newer t-stats will operate duel fuel without the kit like the vision pro from Honeywell.
    Proud supporter of Springfield Millers and Oregon Ducks.
    Oct 2002
    Plano, TX
    I need basics. Coil/furnace set-up. Blower sequence stuff. Any reference material out there.
    Apr 2004
    Ask a specific question, maybe we can answer it.
    The kit usually has the sequence of operation and install instructions. Is that what you are looking for? Not all duel fuel systems work the same, some have outdoor stats or sensors, some dont. In most cases, 2nd stage will shut down the hp and fire up the fossil fuel. Some keep it on until 1st stage is satisfied, some dont.
    There are too many variables as Doc says.
    Some will run 1 or the other, some will fire the furnace for backup. Some return to the heat pump, others keep the furnace going til 1st stage is satisfied. Some are kits full of relays on the side of the furnace, others are controlled by the stat with an outdoor thermistor.
    Are you about to install a duel fuel.
    As far as coil furnace set up. the coil is still after the furnace heat exchanger.
    Do you have a brand in mind.
    Your distributor should be able to provide you with manuals, and a class on them.
