Page 5 of 5 FirstFirst 12345
Results 53 to 57 of 57
  1. #53
    Originally posted by BamaCracker
    Well, I sure did not mean to ruin your day. Sorry.
    If the POE oil in your system has gone to acid, there are tests to determine. If those tests come back positive, Trane will foot the boot for equipment repair or replacement, even though they are not directly at fault.
    The contractor, on the other hand, may not do the right thing so easily.
    Good luck to you and be sure to let us know how it turns out.
    No, no, Bama, not you guys in particular, just the whole situation in general.
    I will ask for them to do the acid tests, I guess. The comapny that came out has apparently been doing a lot of 'after the fact' fixups for HD that had some bad installers in the area. We'll see how it goes.
  2. #54
    Alabama
    Let us know what happens stone, again I apologize if I gave wrong information.
    "If you can't fix it, don't break it."
  3. #55
    Originally posted by stonecipher
    ...apparently been doing a lot of 'after the fact' fixups for HD that had some bad installers in the area...
    Home Depot + almost anything = low end contractors.
    Scream LOUD and LONG to HD & Trane.
    Trane should know better.
    It would not surprise me to see them eat this one to shut you up.
  4. #56
    No, no, my unit was not originally put in by a HD contractor. The tech had assumed I was because that was all of the calls they (the second company)had been getting lately. He was thinking HD was going to pick up the cost of the lineset.
    Now, if the orignal installer, who was a comfort specialist dealer, botched this thing by not following Tranes recommendations of replacing the lineset when moving from r22 to r410a, and if there's acid in there from not cleaning well enough, then yes, someone other than I will be paying for all of this. If I buy a Trane from a Trane specialist I don't expect any shortcuts. I bought a Trane to hopefully get away from all this kind of mess. And I don't think that this guy was the lowest of the bids I got.
  5. #57
    [/B]
    My mistake.
    Looks like the Trane tech made the same assumption.
    Poor guy only gets to see mad people all day long.
    Be nice to the tech.
    Keep us posted.
    Since winter's about over, wake this thread up next winter and post your kwh usage.
