Results 14 to 21 of 21
Thread: through-the-floor-ducts
02-22-2005, 12:28 AM #14
- Nov 2004
- 43
your post is as hard to understand as my last one...i hope you don't wake up each morning to be like me.
02-22-2005, 05:58 AM #15
- Feb 2003
- Huntsville,AL
- 4,125
things sure have changed in 60y in StLouis, MO, then! in the late 1940s, everything had to be inspected in St Louis & in County!
anyway, it would be a good idea to seal any vertical cavity against air flow -- best if firestopping material is used -- critical if multiunit= apt or condo complex! else, it is a lawsuit awaiting.
02-22-2005, 03:29 PM #16
- May 2004
- 18
typically firestopping and angles are only required around a duct opening when the duct is passing through a 1 hr rated assembly. when you pass through a two hour rated assembly a fire damper is needed. most likely the residence is wood construction and the walls and floors are not fire rated.
02-22-2005, 04:41 PM #17
I wonder if it is referring to a supply or return plenum in an effort to make sure combustable floor base is used in a downflow position or an upflow where the return is cut into the floor below the furnace.
02-22-2005, 06:26 PM #18
- Nov 2004
- 43
I usually see it in upflows located in the basement where the return uses the floor joists to link the return trunk to the inside wall via cutting the baseplate (and topplate for the second floor). Register is then placed on the 1st floor drywall and the wall cavity becomes the return. St. Louis public works can't tell me if it is code or not...they don't bother with resi. I guess it's okay because wood floors aren't fire rated like the previous poster noted.
02-22-2005, 09:18 PM #19
- Nov 2004
- 43
I'm going to follow IBC and IMC code and everything should go Okay.
02-22-2005, 10:23 PM #20
- Feb 2003
- Huntsville,AL
- 4,125
wood floors may not be fire rated, but toxic gases flow thru any opening, even flames --
BTW, toxic gases kill within 3 breaths, normally --
one has about 6 min to get out of a bedroom above a room below having just a waste basket fire --
and, think about infiltration
02-23-2005, 01:09 AM #21
- Nov 2004
- 43
Definitely invaluable stuff to be considered
