Results 1 to 7 of 7
    May 2003
    Would the Honeywell Vision Pro 8000 be considered a commercial thermistat?
    There is no definition for commercial stat. With all its features, it certainly would be great for commercial applications.
    Fort Worth, TX
    I manage a commercial building and recently installed 22 VisionPro's into my building, if that means anything.
    They work fine for a commercial building with split systems or RTU's. One advantage is that the thermostat screen can be "locked" without the necessity of an ugly lockbox.
    Building Physics Rule #2:
    Building Physics Rule #3:
    Apr 2003
    Eugene, Oregon
    Some utilities offer rebates for "commercial" thermostats. Their idea of commercial depends on what they want the thermostat to do. You would have to check with them to find out their criteria and see if the stat meets it. If it is just your definition it only matters as far as the equipment is concerned.
    Honeywell does classify the T7300 series as a commercial stat with sub bases and accessories as needed.
    Proud supporter of Springfield Millers and Oregon Ducks.
    Cincinnati, Ohio
    3stages of heat/2stages of cooling
    7day programming
    remote sensor compatible
    dehumidifcation
    still fits more commericial applications than residetal
    Valdosta Ga
    Thumbs up 8570
    I belive AprilAir has a better program option on there tstat with 3 weekly programing options.
    [Edited by bzzline on 02-21-2005 at 10:40 PM]
    Apr 2003
    California
    we use them for both residential and commercial, put it in a com building its commercial, put it in someones house it is residential. as long as it properly controls the unit you are good to go...good luck...
