Results 1 to 15 of 15
Thread: Pipe brace
    Jul 2002
    I need to keep two pipes aligned in all planes. Can't use threaded rod style because they could still move around. Need something like a cage or bars.
    manitowoc wisconsin
    Use the threaded rod style but bolt it to an angle iron bracket.you can fabricate a four point or two point bracket that would hold a truck if that is what you want lol.
    Take your time & do it right!
    Rapid City, SD
    How big is this pipe? I'm not exactly sure I envision what you need, but would a chunk of unistrut and a "cush clamp" work for you?
    Jul 2001
    Southern NJ
    You've got to tell us why!
    Maybe a pair of threaded rod type hangers at each hanger location making a "V"?
    edit: can't draw pictures with symbols, spaces are removed and you can't tell what it is.
    Ryan
    Maintenance Guy
    naysayer, skeptic, conspiracy theorist
    Oct 2001
    if the hangers are opposite each other down the run,cut a piece of rod and place it between the 2 vertical rods on the horizontal.kindorff! cut to catch both threaded rod drops to the hangers,cut one to test the space between pipes,and just go down the line.(if hangers are exsistiing)you want cut the kindorff so the hole is just cut so to accept the rod as you pinch it in between the rods.
    "when in doubt...jump it out" http://www.youtube.com/watch?v=U1qEZHhJubY
    up in the hizzy
    Have you considered up the size of the rod to half " ?
    And for those of you in "Rio Lindo" Kindorff is the slotted green U chanel bar,there are some other heavier gauge U channels outhere,up north where I'live we refered to it as kendorff AKA hanger strap.
    Down here in Texas we refer to it as unistrut.
    Saddle Up!
    Jul 2002
    Here it is
    You can see the mess this is. These joints have loosened twice (and will again) because of the piping moving and loosening the gaskets. There is absolutely nowhere to anchor to so we need to solidly join these together.
    up in the hizzy
    what's the blue stuff ? its locktite? I' dont fully understand how and why the joints are coming loose ,but I' would try some thread lock and maybe a join expansion arrestor or a vibration absorber.
    I' also got an idea from the posted picture ,Can you use a couple of victaulic flanges or couplings install 'em at the very far end of the joins and link them with threated rod?
    Nov 2003
    Boston
    Tough to tell what you got, it looks to me like 1 1/2 galvy tied to 1 1/4 galvy with a dresser reducer coupling and then a 1 1/4 threaded valve?
    It looks like a tough place to re-pipe with new threaded or welded or soldered pipe but thats probably what you'll have to do to prevent the pipes from pulling apart (unless lateral movement is required).
    Dresser couplings are easy to install but they dont make a solid connection.
    [Edited by powerhead on 02-19-2005 at 04:13 PM]
    It looks like a tough place to re-pipe with new threaded or welded or soldered pipe but thats probably what you'll have to do to prevent the pipes from pulling apart.
    Yeah, those couplings gotta go.
    Hey cockroach, don't bug me! ©
    newton,mass.
    Try using friction (riser) clamps two on either end then run t-rod between them. You'll have room to put the t-rod between the clamps at the ends and bolt them on.
    Good Luck!
    "Nothing else can poison our culture, corrupt our society or ruin the character of our people like unearned money or unearned opportunity." -- James R. Cook
    "Fooling around with alternating current is just a waste of time. Nobody will use it, ever." Thomas Edison, 1889.
  14. #14
    Dec 2003
    Good Luck!
    ya, rod the joints
  15. #15
    Sep 2001
    East Stroudsburg, PA
    Lose those Dressers!!!!
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
