Results 14 to 25 of 25
    May 2002
    Another screwed up ALC application. let's see, ALC has managed to screw up Semco, Multistack, MCS.... who am I missing?
    Feb 2005
    What, you are saying you don't like ALC because for example they use 156K baud ARCnet for their BACnet MSTP backbone. Who comes up with this stuff !!!
    lw You have an ALC portal that is custom made and programmed. Next to impossible to get any information about it without forking out some cash to ALC.
    Jan 2002
    Fort Worth\Dallas, Texas
    You guys are really encouraging.
    May 2002
    Another ALC portal disaster apparently.
    I noticed that they have there own UPM style circuit boards.. Apparently the $5 to make it LON was too much for them.
    Jan 2002
    Originally posted by sysint
    Got any MCS web links?
    Here is the link http://www.mcscontrols.com
    May 2002
    lwarren- call MCS. Looks like a Modbus protocol device.
    Rather than use that stupid ALC portal (very expensive) get some information from them to use a Modus/LON gateway.
    Initially I'd say Fieldserver, although Amigo has a link on a recent LON post (by Cardinal?) to a slick little European gate.
    Then throw that ALC piece of junk (for LON) in the trash can.
    Jan 2002
    We did not supply the portals, probably going to be hard to sell something else altogether unless we just cannot make these work. According to MCS they have sent out plenty of the portals for lon integration to their MCS-8 controllers and ther has been no problem.
    I probably don't have something configured right, or I still think there may be an issue with the xif file.
    I would'nt mind the challenge of making this work if time was not so critical.
    Thanks for all the responses everyone, I will keep yall informed.
    May 2002
    "According to MCS they have sent out plenty of the portals for lon integration to their MCS-8 controllers and ther has been no problem."
    -you think they would tell you it stinks? Lets see $2,500+ for the ALC junk... I'm thinking real easy to sign up with Fieldserver or even put the $5.00-$15.00 into making a LON controller.
    And if they use somebody like Loytec you don't even need the Neuron.... (stupid reply #1)
    ......and have hundreds of variables (stupid reply #2) which should help you answer their 2 stupid points they will try to bring up. (being BACnetter-brainwashed courtesy of ALC{?}. )
    How many points do you need to run a heat-pump? Interesting a company would spend thousands on something that should be hundreds. That's what happens when it's not LON.
    Jan 2002
    The portal I saw on their website was $3750.00. Thats incredible!
    Bye the way sysint, this job also has some large Carrier self contained watersource VAV units that Carrier is sending us a lon interface for. Anything thing special I should know or do for these?
    May 2002
    Carrier's LON interface - They actually have some flexibility.
    You configure/MAP through CCN. Maybe have the Carrier rep send you an XIF and you tell them all the extra I/O points you would like to have. For instance, you may want all the transducer data if available. Really, any data their stupid overpriced little touchpanel has you should be able to get.
    We had a problem with the beta-cards needing to be powered slightly after the onboard CCN controller. They may have solved that problem.
    Jan 2002
    Well after months and months of trying to resolve this problem, it has finally been figured out. Honeywell came out to the jobsite and tried to commission this hunk of junk with Care, Lonmaker, and Tridium. The device would not commission. Then they noticed that the Subnet and Node Id for the device would not change from 0-0. The only way they could get it to change was through Honeywells Excelon software. But, if you lost power to the portal the the stupid thing would revert back to 0-0. So whenever LNS would try to set the Subnet and Node for these devices they would not take it.
    So now we have to remove all of these portals, ship them back to automated logic so they can change a parameter in the portal to accept the Subnet and Node ID's.
    These guys need to stick to bacnet!
    May 2002
    Lwarren - you could can those dogs for ilon100's if the controller in the heat pump is Modbus. Then connect the Modbus directly to the ilon100 (e3) and you are good to go.
    They get ridiculous money for those dogs. Guess that's why Army Corps says what they do about the BACnetter's.
